Screen turned purple whilst browsing the internet, the laptop then shut down. After several attempts the laptop rebooted but after windows reloaded the screen turned yellow and the laptop shut down again.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
SOURCE: startup problems
Based on your post/description "barely make out the screen" you have a backlight problem which can either be the CCFLamp or the inverter that powers it. The problem may be component failure, heat related or cold solder, loose connection.
Since this would involve opening the screen display panel, electronic circuitry diagnosis and possibly component replacement, your best bet might be to seek the services of a qualified repair person. To give you an idea of the possible cost, pls refer to this site.
Should you venture into giving it a go for yourself, this site might be able to give you an idea how it is done. This link is a possible source of replacement components.
Hope this be of some help/idea. Post back how things turn up or should you need additional information.
Good luck and kind regards.
SOURCE: TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
SOURCE: Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
SOURCE: won't boot up on first try
Whenever you do get it booted into windows, run the command prompt and in there run "chkdsk /f". That will check your disk for errors and repair them. Yours sounds like a boot sector problem, chkdsk should be able to fix that.
Samsung R540-JA08
