Question about Craftsman Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
Go to start my riding mower and it backfires as i am trying to start it. but runs fine once running. doesnt backfire every time starting it. mower runs dam good while mowing. any clues what might be causing this ? thanks
    New Friend:
  • 4 Answers
My bet is the way you shut the mower down after the previous mowing?.Common problem is shutting down the hot engine while the throttle is in any other position then full idle...two things can happen when this is done...a backfire seconds after shutting down or starting up due to excessive gas left in the cylinders and intake when shutting down ..so try this pull the throttle to full idle and let run for 30 seconds or so the turn the switch off..all gases will be used up.. Works for me...good luck..
Posted on Jul 17, 2015
    Brigadier General:
  • 6,468 Answers
First smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Posted on Apr 19, 2012
  • George Dubbs Dec 04, 2014
    sometimes these motors will load up tne cylinders with unused gas if you shut it diwn while not in full slow idle..try this make sure you throttle back to full idle fir a few seconds before shutting down..that will allow all tne gas in the cylinders to be used up..this happens to my craftsman 22.5 hp.. Stops it every-time..good luck
6ya staff
SOURCE:
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
Posted on May 22, 2009
Anonymous
  • 77 Answers
SOURCE: engins starts and runs when mowing will backfire and stall.
First,if your blade is bent and hasnt been replaced yet,do it, second make sure your timing is still right on your engine.
Posted on Aug 09, 2009
john h
  • 22486 Answers
SOURCE: lawn mower not running
sounds more like the carb sucked up something if u take it off and tear it down let soak in solvent than blow air thru body to dry and clear passages dont mess with adj
Posted on Sep 24, 2009
k8treed
SOURCE: After running husquavarna riding
I had the same issue and after trying everything I tokk the gas cap off and noticed there was negative pressure in the fuel tank when I broke the seal... I'm pretty sure the gas cap was just too tight, I threaded it back on but did not torque it down and the mower is running fine.
Posted on Jun 16, 2011
mike butler
  • 6468 Answers
SOURCE: My Sears Riding Mower Runs Rough & Backfires
don't know the model but check the valve adjustment
Posted on Apr 08, 2012
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower not running
Sep 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It Starts and runs fine for about 15 minutes then
I think that your right. Sounds like your ignition coil witch is most likely located under the the flywheel cover. I know that on some briggs and stratton engines they are actually under the flywheel, just trace the sparkplug wires to know for sure. When the ignition coil beginns to fail they start slowly (spitting and sputtering) and then they get to the point to where they stop firing after getting heated up and adventually quit all together.
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Garden Logo
618 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
