Question about Zebra Symbol MC75 Handheld Mobile Computer Portable Terminal
Mc75 i want to use symbol.barcode.dll to init the laser
The C# app inits the camera to scan barcodes. Instead of init the camera, I want to init the laser. Datawedge will init the laser but I have better control over evaluating what was scanned using the symbol.barcode.dll and do not need to have focus in a textbox to collect the scan. The .dll inits the first available datareader (camera). Any ideas on how to init the laser instead?
  • Ron Boren Apr 20, 2012
    I talked to Symbol tech and he explained that OEM versions 21 or less (old) default the camera first in the registry, then the laser second. The newer OEM versions have the laser first then the camera. A registry change is required to to have the laser first on the older OEM versions, but it might be easier to upgrade the phone software.
6ya staff
SOURCE:
Anonymous
SOURCE: Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Posted on Apr 16, 2008
Joe Blow
  • 257 Answers
SOURCE: ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Posted on Jul 15, 2009
tcholt
  • 9 Answers
SOURCE: Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Posted on Aug 31, 2009
Testimonial: "Thanks. Printing out the settings helped me realize it was not a printer issue. It was a software issue. Installing older version of software fixed it"
kganoe
Kim Ganoe
  • 42 Answers
SOURCE: I installed Datawedge.exe in my MC75 device.
We have set up many of these device with Datawedge. The configuration depends on what type of barcodes you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
Posted on Mar 17, 2010
kganoe
Kim Ganoe
  • 42 Answers
SOURCE: motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
kganoe@datexcorp.com
Posted on Mar 25, 2010
Hello, I have a custom application but the scanner won't work with it. is there some way to enable the scanner to tell it to work. I have a quick scan sample app that works fine, but my custon app...
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Aug 04, 2011 | Zebra Symbol Technologies MC909X-G Series...
Dear Sir/Madam, I have Motorola PDA (N-410), Windows Mobile is inside. Microsoft Office is also inside. I want to use the excell sheet, with the barcode scanner. Means if i Scan the barcode by using...
You would need an application, which can use the scanner. If there is no app preinstalled use the DataWedge provided by Symbol on their support pages.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=10774
You can install the whole package on the desktop PC and then connect your PDA. The DataWedge will be installed automatically.
Oct 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
The scanner will not scan any barcodes. The red light lights up but nothing ever happens
The barcode is probably not enabled in factory settings. I would propose to use the manufacturers software called DataWedge, provided at support.symbol.com and check again. If you still have no luck try to find out which kind of barcode is it, by the producer and enable it in the settings of the software. Or better just select the option "Enable All" in the Basic configuration of DataWedge
Sep 29, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Scan bar code using motorola MC75
Jul 15, 2010 | Zebra Symbol MC75 Portable Data Collector...
Motorola MC5590 is not able to scan barcode
Mar 25, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Im using DataWedge v1.0 for scanning the barcode in Motorola MC55.How can i get scanned data from DataWedge to my application.i.e where DataWedge will store the scanned information.Thanks.
You need to be in an application first. For example, launch mobile Excel and make sure your cursor is in a cell. When you scan, it will enter into that cell. Just make sure the cursor is in the cell you are trying to get the info into before you scan (If it's not working, the app you're running may not be compatible with the scanning function, but I've never seen this).
Oddly enough, from what I've seen, if you just scan something without having an app launch, I've seen the MC70 default to the phone function and try to dial the number scanned.
Feb 18, 2009 | Symbol MC70
Laser does not scan using Internet Explorer
Try starting the ScanWedge prior to opening the Internet explorer browser. ScanWedge can be found under the Applications partition.
Jan 09, 2009 | Zebra Symbol Technologies MC909X-G Series...
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Open Questions:
Zebra Symbol MC75 Handheld Mobile Computer  Portable Terminal Logo
303 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
