Industry standard PC, XT, AT, and LPX motherboards use the same type of main power supply connectors. They use two main power connectors: P8 and P9. Each of the P8 and P9 connectors has 6 pins that connect power supply to the motherboard.
Chances are the lamp was reinstalled and didn't get put in the right position. There could also be a problem with the concentrator/heat shield lens or light pipe (if it has one). Sounds like either someone replaced the lamp and didn't get it back together or the unit has been dropped.
It sounds like you need a new ballast unit for your screen. It cannot be a processor problem as the laptop works OK on another screen. The ballast unit is beneath the screen itself. Check ebay for a keen priced ballast unit or complete screen. Hope that helps.
Hello sounds like you have the logo screen burned into one of your LCD panels. This will be a very expensive repair, seen as the LPX-500 is only an 800 lumen projector, it would be a good time to look for a replacement. I would not recommend spending any money on this unit. Hope this helps Projector Guy
Welcome to the disapointing world of LCD projection. Your blue device is dying and thus allowing the green to come through instead of combining for white. I suggest buying a dlp product they are immune to this color decay problem. Good luck
I just saw your post & today is Mar 19,2008. I had the same problem and was pissed until I noticed YAMAHA has a good warranty, so I sent it back and they put in NEW OPTICS that are non-organic (I guess the original ones were organic) NOW my picture is much better than when it was new. This picture is so clear I can not believe it.
