Brand New Sony Vaio VPCEH , Almost overload CPU all the time.. (when i do nothing CPU usage 45-60 %) I have Antivirus Kapersky Original
The CPU is runnimg with a useage of 45-60% as soon as the laptop has booted up because Kapersky is upgrading the virus definition file and is running a virus check on the files stored on the hard disk. When Kapersky has finished these tasks then you will see a drop in CPU useage.
NOTE as you install more programs and as your data files increase so will it take longer for Kapersky to carry out the virus scan.
SOURCE: I just bought a new Acer Aspire 5534, it has
yes you can upgrade the cpu but you will have to dismantel your computer to get to the processor.
and you must be ready for all the headaches that will come with it. now the real question is ,.... is it worth it>? NO its not worth it because acers ar proned to motherboard failure after upgrading the processor.
also they are proned to burn in failure. try adding ram if that dont do it i wouldnt stick too much into that model of computer.
SOURCE: Hi all i have a little question I got ASUS A9RP
there should be no difference other than the core clock. They should be the same socket type.
SOURCE: How can i play NBA 2K10 on my sony laptop?
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena33
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
