The Beamer does nothing. I turned it on and after 3 minutes the qualia 004 turned off. Now i can not turn it on. What can it be?
Hi the problem is in the board GB, open the projector and find the GB Board an change only one component, the MCZ3001D! The board have two McZ3001D, only change the side position!
Max, can you help me in locating the GB board and how to replace the MCZ3001D. Thanks in advance.
Hi Max, can you please help me locate the GB board and the steps to replace the MCZ3001D. Thanks in advance.
Hi in the user manual you can check in the replace lamp, how you can remove the cover, is easy you need only remove 2 screws and slice the cover! When you open the cover, if you look the projector find the board in the picture that I posted today, you can read in the board GB in white color! In the board you have 2 mcz3001d, one in the center of board and one of the side, you must be change the mcz3001d of side. Only one. But you need a technician expert to change this component!!!
Thanks for your quick reply Max. My projector is not turning on and I assume that its a power supply issue, right? Is the MCZ3001D the replacement IC for the power supply? Please confirm. Much appreciated.
Yes! If your projector is dead, no red light, no power on, its the mcz3001D. You can buy the MCZ3001D direct on the web of Sony Professional:http://www.sony.com/servicesplus Or call to tel:1-800-538-7550 I asked to Sony for the entery board and they told me: "The part GB-Boad cannot be purchased. Your part will be refurbished at the same cost of a purchased GB-Board, $997.09." But the MCZ3001D : in the manual service the part is: IC201. Part requested: 875967030 Part supplied:670581001 Part: IC MCZ3001DB for $17.26
I forgot the projector model for search any part is Q004R1, if you call to Sony you need this reference, thank you!
Thanks a lot Max. I opened it up but as you said I may need the help of a technician to replace the part. Thanks for the help.
