Boating Logo
Linda Orrison Posted on Apr 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you refinish a plastic kayak
My kakak is faded and ugly but in great shape. Is there a way to refinish it?
John Mabry
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Jun 22, 2016
John Mabry
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
99835
Points
514
No poly-plastics of the type used in manufacturing can only be armor-all surface cleansed but makes the craft very slippery to lift and use. Color is restored though. Make sure there are no brittle areas that have been 'cooked' by the sun while stored in a yard. IMPORTANT!
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Sep 18, 2012
SOURCE: Can I refinish a plastic kayak?
paint and clear coat
How to safely mount my akaso 7000 to my kayak.
Depends on how much you don't want to drill holes in your Kayak...
The camera presumably will accept a standard threaded mount of which there is a multitude of different types available.
If you prefer to use the suction mount it will need a really smooth surface to remain secure. The best method of achieving that would be to bond suitably sized pieces of shiny plastic laminate to whatever flat areas of kayak are available.
If you want a horizontal mount at the top of the peak or curve of the upper deck just forward of the cockpit coaming, an adaptor will be needed. A piece of fine hardwood could be shaped to provide a close fit suitable for bonding or screwing to the kayak upper deck which will in turn present a flat surface for some plastic laminate.
Sep 29, 2018 • GPS
Plastic piece on back of seat busted looking where to find replacement its for a dirigo 120
I would say the best thing to do would remove the screws/bolts/hardware
plug the hole with whatever you took out. and buy a new seat with a higher back.
you may need to add those u shaped deck cleats but thats not a big deal
2answers
What is the best way to remove oxidation from a fiberglass kayak. The color is very faded from years of direct sun exposure. Kayak is >15years old. I want to restore the original color and luster.
There is really no easy way short of sanding lightly and repainting. (I am told that "tremclad" paint intended for exterior use on metal in tough situations is good for this kind of thing.)
Wax (car wax or wax for fibreglass boats--which is often available in colour) will work for the short term.
Mar 17, 2010 • Boating
Our sit on top kayak is about 7 years old . t6he seat area has bulged up and underneath it has also bulged out . it is a catatmaran style kayak.
I do not know what you mean by a catamaran-style kayak.
I am assuming that it is a plastic kayak,. like most SOTs. Reshaping plastic boats can be difficult. If it was my boat I would try:
  1. If bottom flat, lay on flat floor like garage or deck. If not flat, then work on lawn.
  2. Let the sun (and maybe a bit of extra heat, but not much) warm the bottom so it is a bit pliable.
  3. Apply force to put the bottom back into shape. If not a flat bottom, then some extra care is required. This is usually done with internal blocks of wood or foam to hold the hull in its proper shape. In more extreme cases you can inflate an air bag in there to maintain pressure over a larger area. (BE VERY CAREFUL if you use an inner tube--it can burst your boat!)
  4. Once it is back to about the shape you want, leave it in that position for up to a few days, but at least long enough to cool down.
  5. With any luck, that will reverse most of the dents. If you don't get it all the first time, you might want to try again. In fact, I suppose it might be better to work on it twice rather than do too much in one go. I really am not sure on that part.
  6. With these poly boats, you may never get them back to original shape, but they will almost always accept some re-bending to get back to a more useable shape.
Aug 12, 2009 • Boating
2answers
Is the yakima big stack safe for fiberglass kayaks
I used the big stack for my river kayaks and it did fine. But my fiberglass sea kayaks are so much heavier that I did not take the chance. For 1 of my kayaks I spent a lot of money to get the special sea kayak rack and it worked great. For my wife's kayak I saved some money and bought some simple v-shaped foam rubber rack attachments for $20. The foam attachments are so much easier, I don't even use the Yakima attachemnts any more. My suggestion - save your money and go with the cheap foam attachments.
1helpful
2answers
The headlights are worn out and cant see the road at night
get a lens refinishing kit on ebay or at parts store
3answers
Small crack in hobie kayak
what is the canoe made of... it may not look pretty but fiberglass will work.... you can sand and paint it later as well
Top Ocean Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an Ocean Boating Expert? Answer questions, earn points and help others
