And some fault and its solutions.
You can download the complete service manual including the schematic diagram also.
Here is the link.
Unfortunately there are many possibilities of faults and so I can not give you any solution. You should have given description about the problem.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
MPI CONTROL RELAY AND FUEL PUMP
RELAY CONTINUITY CHECK
UNDO THE RELAY CONNECTOR
1) Without Battery Voltage: check continuity between connector terminals 2 & 4
2) With Battery Voltage: connect 12v battery power to connector terminals 2 (-) & 4 (+) . Then, check continuity between connector terminals 1 & 3. Refer to diagram below:
If the relay connector does not measure the correct continuity, then replace the relay.
Cheers,
"If this solution has helped you resolve your problem, please be kind enough to leave a testimonial"
