GIMANA CARA MEMPERBAIKI PANASONIK KX MB2025 EROR CALL SERVICE 3
Gimana cara mengatasi masalah call service 3 printer laser panasonik kx mb 2025????
Call service 3 772
SOURCE: hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
SOURCE: Panasonic KX-MB263 - CHECK DRUM- error
The drum unit must be nearing the end. You will need to replace it soon. Check the page count and check for howmany pages the drum is rated for. If the pagecount has reached the rated count, then its ok, if you are far from the rated limit, you will have to check with the supplier for possible refund.
SOURCE: call service 6 error in kx-mb262 panasonic
Call service 3 error in kx-flb802
& factory reset
SOURCE: kx-flm600 call service lp
I have the kx-flm650 and have the same problem. I tried calling the company who made me reset some things to no avail. They tried to sell me a new fax machine. It is too bad, as it took a while to get drivers to work with win XP
where is the solution for this problem
