Dishwasher pump was continually running when door was opened. Took the washer out of the cabinet and tipped drained as much of the water out as possible to reset flood switch. Now the pump stops when opening door is opened but continues to drain cycle when the door closed and will not move on to the next cycle. Is flood switch still engaged?
The unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
SOURCE: dishwasher keeps running
sounds like a problem with the pressure chamber. you better have a appliance tech come out to fix it.
SOURCE: Bosch Clasixx dishwasher sticks at point when it drains water
you have a clog remove the float clean and replacs,sould work now.
SOURCE: DISHWASHER DRAINING POORLY
the drain on that model activates about 4 times for a couple seconds before it go into the continual drain. it does that so debris can fall downwards easier during the drain. its also supposed to have about 2-3 inches of water left below the iron mesh filter when its complete, if its above the filter than you have a drain problem. if you do have a drain problem then yes check your airgap first if you have one to make sure that isnt clogged. if your issue still exists then send a message, im sure we can figure it out
