Certain lights will turn on and i can cancel and drain it but wont run
Check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Maytag Dishwasher will not start.
I had the same problem. The plastic wiring strip that connects the touchpad had corrosion from water. The panel would need to be replaced, because they don't sell the touchpad separately. (around $50 - $70 USD)
SOURCE: Maytag Dishwasher won't drain
on all dishwasher think of them as a simple gutter system. the water only has one drain. At the bottom, if the pump can't pump out the water, its simply a bad pump or a clogged drain hose. Food particle can clog the "drain screen", use a good quality shop vac, clean 'drain screen', remove drain hose and clean thoroughly. If the hose goes into your drain pipe, remove that and clean that really good with snake it its metal or a strong 1/2 zip tie if its plastic.
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: maytag dishwasher mdbh945aww3 does not start
you have to get the touch pad replaced. my worked for 11 month, got it replaced (3 weeks to get the part), worked for 1.5 month and broke again out of warranty. time to get a new dishwasher and extended warranty. maytag is total c$%p. Everything is made in Mexico. I think even China makes a better product. WOW did I say that?!?!
SOURCE: Maytag dishwasher MDBH985AWS1 won't drain
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
• Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
• The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
My wishdwasher will start the stop approximately 5-6 times in a 30 sec. Period then it shuts off to a cancel position on the touchpad any suggestions
