Maytag Bravos MTW6600T Top Load Washer Logo
Posted on Apr 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag bravos washer will not complete cycles
Washer will not complete cycle and displays an "Ld" error code. Try to restart it and will not go through. Takes a whole day to do one load of clothes.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1474
Points
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
  • Anonymous Oct 01, 2012
MARLON KELLER
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Apr 17, 2012
MARLON KELLER
Expert
Level 2:
Scholar:
Answers
111
Questions
0
Helped
50652
Points
241
Ld code means long drain, which can be caused debris being stuck in the drain port generally in the tub to drain pump hose. It can also be a bad drain pump all together. It is not hard to change or check for debris and is easily accessible from bottom of unit however you will need a shopvac and towel due to the fact the unit does hold about 3 gallon of water down below the agitator you cant seefrom the top... slowly undo the tub to pump hose and siphon water out with shopvac until all water is drain then remove pump and inspect for debris. most times a coin or small sock or thong will clog it up. PS where some clothes you don't care if they get wet or dirty.....
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
5 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Dec 27, 2010
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
sivaranjini
Sivaranjini
  • 241 Answers
  • Posted on Jun 22, 2009
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Anonymous
  • Posted on Mar 18, 2009
SOURCE: Maytag Neptune Error COde "nd"
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Anonymous
  • Posted on Jul 03, 2009
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
michael
  • 155 Answers
  • Posted on Nov 07, 2009
SOURCE: Ld error on Maytag Bravo. How to remove items stuck under tub?
if you can see the socks you may be able to remove by making a wire hook with an old coat hanger or something similar if you are able to undo the hose coming out of your bowl to the water pump you may be able to also fish out the coins if you are lucky but the best way is to dismantle bowl let me know how you went
My Maytag BRAVOS MCT Serial #CY5170277 ModelMVWB750WQ0 has stopped mid cycle.
To retrieve error codes from your Maytag BRAVOS MCT washing machine, you can try the following steps:
  1. Make sure the washer is in standby mode (all lights off).
  2. Select any three buttons (except POWER) and follow the steps below, pressing the buttons in the following order within 8 seconds:
  • Press and release the 1st button
  • Press and release the 2nd button
  • Press and release the 3rd button
  • Repeat this sequence two more times (a total of 3 times)
  1. If the buttons are pressed in the correct sequence, all indicator lights will turn on for 5 seconds and then turn off except for the "lid lock" indicator.
  2. The washer will then start a diagnostic test cycle and the error codes will be displayed in the "Estimated Time Remaining" display.
Note: Make sure to write down any error codes displayed on the screen, as they will be helpful in troubleshooting the issue with your washer.
I have a Maytag Bravos Quiet Series 400 with steam I get an error code of fo1 it was overly pack up with lint, but I have got it all out front and back still have an error code
https://www.youtube.com/watch?v=xpTCLMugh60
https://producthelp.maytag.com/Laundry/Washers/Washer_Product_Assistance/Error_Codes_in_Front_Load_Washers
From the Maytag site: To remove the code, press pause or cancel button twice and the power button once. If the code is still displayed, unplug the washer or disconnect the power for one minute. Items were detected in the washer during the Clean Washer cycle. Remove items from the drum and restart the Clean Washer cycle.
Every other wash sd code come on
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
1helpful
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
I am getting a F50 code on my bravos, what does this mean
go to the makers website for a user manual there usually free to download and you should find an answer eric
My washer shows an "ld" code after stopping in the
I have looked and looked and can't find an error code "ID" for any Maytag washing machine! Are you sure that is what is being displayed.
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
