Hi, The Video works fine and picture is clear through the video input. But when we set the input to INPUT A - the screen goes black and blue and starts shaking and rolling. nothing is visible. How do i fix this isse. Please help
Seems you burned one line actually A output i would say even input but you have to check line a
how do i check line a? can i do it at home or does it need to be opened up and the main board be worked on?
Okay it got a lil better. Now i can see the right hand half of my screen! the left hand half and the start button are not visible. If i move my windows further left then dim dark lines start appearing. I Got to this point by simply changinf my resolution to 800 x 600 on my monitor.
SOURCE: Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
SOURCE: Panasonic PT-L501U
Hi BEEZELLE
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
SOURCE: trying to connect scart to video input but unit
Ok SCART is meant to be a "Standard" meaning all SCART should be the same, unfortunately they are NOT. Please have a look at the Wiki link below it will explain all. Some SCART plugs do not have all connection wired through, you must ensure your SCART cable has EVERY wire intact, we usually meter out our plugs to check, as we have been caught out too many times, usually the High end, ones are OK
http://en.wikipedia.org/wiki/SCART
