Have Lenovo c3000 c100 but its touchpad is not working when i plug the charged then its sometime working or not so please tell me the solution of this troubleshoting
SOURCE: Laptop's touchpad not working
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
SOURCE: mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
SOURCE: i want audio driver for lenovo 3000 C100 can u
Please find here enclosed URL: http://www-307.ibm.com/pc/support/site.wss/MIGR-63531.html
Download and install.
Thanks & regards
Nanda Kishore.
SOURCE: my touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
