McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
Posted on Nov 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just won't start
I put fresh gas in brand new generator, oil is full and spark plug sparks, but not wanting to start
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1238
Points
Check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
johnny rebel
Level 3:
Top Expert:
  • McCulloch Master 10,875 Answers
  • Posted on May 12, 2013
 johnny rebel
McCulloch Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942264
Points
47944
jyocum800
Level 1:
New Friend:
  • Posted on Jul 06, 2012
jyocum800
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1689
Points
Brand new titan generator 7500D purchased years ago, shrink wrap just taken off Does not start. Never had fuel in it.
Found issue filter located in the tank & rubber boot was issue. unfortunately Titan Generators is out of business they do not answer Phone, faxes are returned, emails are maxed & not accepting any.
Does anyone know where to get Titan Generator parts?
Why will my saw not start, good spark new plug fresh gas
Sounds to me like a plugged up fuel line or old fuel in the fuel line. You may be able to clear it by spraying some starting fluid into the carb to pull the old fuel through. You only want to do this 2 times because this has no oil in it. Another suggestion it to remove the spark plug and put some of your fresh fuel mix directly into the chamber. About an eyedropper full should work.
2answers
Generator wants to start. It fires for a couple of seconds then shuts down.
there will be a oil level control unit on the engine sump that has a habit of failing on a regular basis
test it or replace it.
2answers
Won't start. Just put in a new spark plug and fresh gas. filter is clean and so is the oil
Take it back to the dealer. These small units have a 12 volt DC
generator that is internally converted to 120 volts AC. As such
they are fairly complicated.
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
2helpful
3answers
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 • Garden
Have a problem with a BS600-W-1 generator
With your model number I could see if it has a low oil safety switch I have seen them go bad (check your oil level )
With all wires un plugged from the coil you should have spark
if not coil is bad .
Use another spark plug to test for spark, ground the side of the plug by holding it against some-ting metal on the engine , spark
plug wire hooked to the plug. leave a spark plug in the cylinder
head so gas wont fly out and hit the test spark plug catching fire (seen it done).
Good luck
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 • Garden
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
