Hi, i have a Dlink wbr-2310, right now when i plug in the power cord, all the lights that on the router are on. and the computer says no connection at all, local and internet..none of them is working,, the reset butten does not work,,,the router seems like frozed.
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
I have the exact same problem. All of the light on the router are on, but I cannot get a connection. I have tried resetting the router, cable modem and PC, but nothing seems to reset the router.
exact same issue
Exact same issue here... very frustrated
same thing here, was working fine last night, woke up - all lights are on, nothing plugged into it other than power.
i have the same problem. Its not the modem because i plug directly into the modem and im on the internet. It is the router.
I have the same problem. Can't access the controls, since they are all web-based! With no connection working on the router, its impossible to fix. Empt970005's answer doesn't help, as I bought this 2 years ago. Did I miss a firmware update?
Same problem here. One night it was working and the next it wasnt on
Same here
Works for about a minute or two, then just stops working and disconnects from my wireless card. My computer shows every Wifi signal in the neighbourhood, and also shows that my wireless router is broadcasting NO signal! It is a month old. I'm taking the damn thing back!!
my internet connection gets cancelled all the time and i have to consrantly disconnect and reconnect.
I have a similar problem, I cant connect to the wifi or lan cable everytime I plug adapter after a long time being off. What I normally do is unplug the adapter for a few seconds then plug it back again.
I have the same problem. I the modem signal started dropping out and I unplugged the power and internet cables to get it back, but after about a week of doing this the modem is completely frozen and all the lights stay on/do not blink. It's a couple of years old so I know it's no longer under warranty. I will not be getting another D link!
why is this happening
All the lights for the PC's connected stay on... and not flicker meaning there is no PC activity. I hit the Reset button in the back and all the PCs try to identify the network but get nothing out of it... i try typing in the default IP to see the settings and i cant even do that.
Same problem :S!!
dont know what to do!! LS
