I have a kodak easy share 500 I plugged it in to upload pics to my comp and its just stuck on the opening screen saying kodak easy share system... Even when i put the memory card in , it doesn't go anywere else its just stuck here i can't transfer pics or print anything
SOURCE: help
go to the link below and download the driver:- http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn032918.jhtml?pq-path=10810
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
SOURCE: My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: I have a kodak digital easy share cd33 camera,
1. With no card in the camera, go into the menu and find "reset"....follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 3. Insert card, go into the menu and do the "format" thing again. Be sure to download any pics from the card first.
