I have a new monitor. My screen image has a thin blank/black space on the left, and on the right it is just enough off the screen that I see only half the X in the upper right corner for closing the screen. My up/down scroll column on the right is just a sliver that I can just touch with the curser to use.
The adjustment buttons on the frame of the monitor are a mystery.
TV - analogue (S-Video, composite)
X
X
X
TV - analogue (component)
X
X
VGA (with EDID)
X
X
VGA (without EDID)
X
Digital (DVI, DisplayPort, or HDMI)
X
X
Digital (HDTV via DVI, DisplayPort, or HDMI)
X
X
LVDS (notebook display)
X
If the feature is supported, the corresponding tab is available on the Adjust Desktop Size and Position page. If only one feature is supported, then only the controls for that feature appear on the page and there are no other tabs.
Scaling
The scaling controls let you adjust the size of the desktop to best fit your screen. The configuration that you specify may be overridden by the settings in the Resize section.
Select a scaling mode
Aspect ratio: This setting expands the desktop as much as possible while maintaining the same dimensional proportions, or aspect ratio, as the original image. There may be some black borders, but you may prefer this setting to avoid distorting the image.
Full-screen: This setting stretches the desktop to fill the entire display screen.
No scaling: This setting leaves the display image in its original size and centres it on your screen resulting in a small though crisp image. A black border may appear around the display image.
Perform Scaling on
GPU: This causes the GPU to scale the desktop from the set resolution up to the native resolution timing.
Automatic: This setting uses a combination of display and GPU scaling to scale the desktop from the set resolution up to the native resolution timing.
Override the scaling mode set by games and programs
When this check box is checked, applications cannot change the scaling mode set on this page.
Preview
Under the Preview section you can select a resolution and refresh rate, and then the preview image shows how full-screen applications will appear on the screen, using the selected scaling configuration. The available refresh rates will depend on the scaling method selected.
Resize
Some displays, such as HDTVs, extend the edges of the display beyond the visible borders of the screen. This overscan is intended to hide broadcast data that is not intended for the viewer. This results in hiding useful parts of the screen for non-broadcast content, such as the Windows desktop.
The best way to resize the screen in order to view the entire content is to use the controls provided by the display hardware.
The resize controls on the NVIDIA Control Panel are provided in case satisfactory results cannot be achieved using the controls on the display.
Position
Use the arrow buttons in the image under Adjust the desktop position to adjust the position of your desktop or image on your screen.
SOURCE: Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
SOURCE: Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
SOURCE: SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
