Pentax Kr Digital Camera Logo
Posted on Apr 16, 2012
Shutter clicks ever time I press a button & it won't take pictures
Unable to take a picture & the camera clicks like I've pressed the shutter button every time I press any button.
  • Betty Ong
    Betty Ong Nov 27, 2013
    this is an old model, not yet a digital one
stace8383
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 15, 2012
stace8383
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
470
Points
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
4 Related Answers
halotheracer
halotheracer
  • 69 Answers
  • Posted on Mar 09, 2008
SOURCE: shutter on k100d
Maybe you can try sensor cleaning mode;
Go to Menu>Set-up>Sensor cleaning, press right than choose "Mirror Up", wait a moment than power off the camera. Maybe this can help.
Regards.
-halotheracer-
Anonymous
  • 2985 Answers
  • Posted on May 27, 2007
SOURCE: Shutter wont' release
Well either the relase switch has failed or another projection device has stalled it. Check through you menu of the back screen to be sure and then call Pentax technical support on thier web site.
Anonymous
  • Posted on Oct 11, 2008
SOURCE: shutter release
take it back to the shop
Anonymous
  • 11967 Answers
  • Posted on Jul 03, 2010
SOURCE: When I press the shutter button, it will not take
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Why do i have to click my shutter button twice before it takes the picture?
First click is to show focus and 2nd click is to capture. its common in most camera's. Nothing to worry about.
There is a delay between the time I press the button to take the picture, and when the picture actually is snoapped. Can I make this delay a shorter time?
This is a common situation with many compact point&shoot cameras. The camera has to do a lot of work between the time you press the shutter release button and it takes the picture; set the focus, meter the light and set the exposure, switch from showing the real-time image on the LCD to capturing and storing a single image, and more. Larger, heavier, and more expensive DSLRs have additional hardware to reduce this "shutter lag" to nothing, compact cameras don't.
There is something you can do to reduce the time, however. If you know where the action is going to happen (a kid getting ready to blow out the candles on a cake, for example), press the shutter release button halfway to focus and meter. Hold the button there until the action happens, then press it the rest of the way. This lets the camera get most of the work done before taking the picture.
How do i get my camera from having a time delay between flash and actual picture
This is a common situation with compact point&shoot cameras. Between the time you press the shutter release button and it takes a picture, it has a lot to do. It has to find the subject and focus on it, meter the light and set the exposure, perhaps set the white balance, and other things. Larger, more powerful (and more expensive) DSLRs have more powerful processors and additional hardware to speed up the process.
One way you can reduce this shutter lag is to press the shutter release button halfway to focus and meter before you need the picture. Keep the shutter button pressed halfway until the action hits its peak, then press it the rest of the way.
1helpful
2answers
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
When I press the clicker ( button to take the shot ) it takes like 1 second before the shot is captured, is there a way to speed it up ? I take a lot of pics of bands playing, and I'm all ready &...
You say in your description that you're "focused in". That means that you've pressed the shutter button half-way and allowed the camera to lock in the focus (it will beep). You need to maintain that half-press until the moment you want to snap the picture and then press the rest of the way. That will give you a faster, "instant" picture. Is that what you do?
May 16, 2011 • Cameras
1helpful
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Auto focus
Are you sure you did not activate "Manual Focus"?
Near the shutter button, there's a "Focus" button. maybe you pressed it accidentally and now you're in "Manual Focus" mode.
If so, press it once more to get "Multipoint" mode back to life...
And read the camera manual. It's a goot place to look for this kind of answers.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
