Makes a buzzing noise when you turn the power on and a second later goes to stand-by mode. When this happens the bulb blows.
SOURCE: reset after using emergency close feature
Hi jimmac123
Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
SOURCE: Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: will not turn on
I have just solved this problem. The solution for me was a capacitor in the second PCB of the primary power supply. The Cap was a 2200uf @ 10 volt. Once I replaced this the Projector powered up fine.
