I want to service my keyboard as some of my keys are not working
Remove the Power Cord and the Battery. Turn the laptop over and start removing screws from the bottom of it. There might be screws on the bottom that hold the keyboard, normally they will have the keyboard icon by them. Once you have the screws removed Look inside the battery case to remove any screws. Sometimes there will be screws that hold the keyboard and the strip that is above the keyboard inside the battery case.
Next turn the laptop back over and open the lcd lid. Remove the strip that is above the keyboard. Be careful because there might be a cable attached to the bottom of the strip. Once the strip is removed there might be screws that it was hiding that hold the keyboard so remove them. Now you can lift the keyboard out, but be careful because there is a cable attached to the back of the keyboard.
SOURCE: Looking for the specification of the Sony Vaio PCG-8K2R
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCGTR3AP&upd_id=1087&os_id=7
just click and download your driver
SOURCE: Need pdf manual for sony vaio pcg-394L
hello
Go to the Sony web site serving your contry and download a manual. Here is a link I obtained from the US site after entering the model number you provided.
www.docs.sony.com/release/VGNFZ200series.pdf
Apparently, it does not coorespond to your model. But not knwowing from what country you sail from, I cant't be more accurate.
Hope it gives you a starting point.
SOURCE: vaio pcg-3e2l fan replacement/how to open for
Ask sony first if they still cover the fan replacement for this specific model VGNCS220j/w
If they tell you they dont, then you can setup service for the unit in sony.com/repair
