Beac tv
002/ 006/ 071/ 128
Had an encounter on this tv brand BEAC, and actuated chunghop model RM-133e codes are as follows: 013, 073. Note these codes are a "SAFE" codes. I would suggest not to touch other buttons if you are going to use any universal with manually set functions. As you will get a problem (e.g: Factory on the screen, "CHILD LOCK" displays or a LOCK icon on the screen and so forth. Thanks for using Fixya.
What is the code for skyworth hd7400a digibox the remote is keyin 133e
What is the code for vista TV
The remote is Keyin RM - 133E
code a vision tv
hi what code a vision tv
Code for pensonic p
What is the code for ovation TV. The remote is key in rm 168E
What is the code for coby the remote is keyin RM-L1107+3
What are the code in philips
What code to 21V-W80M sharp tv
Hi what the code for ktc led tv
What is harier code??
SOURCE: may I please have the code for kevin RM-133E code
Here are the following codes that you can try:
SOURCE: i have a chunghop universal remote, RM-133E and i
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
SOURCE: chunghop remote control RM-133E LG
Hello
Codes for LG tv with Chunchop RM-133E universal remote control are:
024/040/098/043/040/259/260/261
OK.
SOURCE: CHUNGHOP RM-D203...I CAN'T FIND THE CODE OR MY BEAC TV
i can't find the code of RM-D203 can you please send me the code for sony in my email
Codes for tcl may remote is keyin rm-133e pls
hi pls help can anyone know the code of ezy led tv
how to return the volume ?
Code for my view
What is the code in samsung please i want to know now
code for ezy led tv pls.
Code for PCL pls
What is the code for haier tv, keyin universal remote
what is the code for lg
what is the code for sharp
Code for ace tv pls
Code for ace tv pls
code for avision tv
Code for ezy please thanks
Code for skyworth hd7400a remote is keyin 133e
Code for Daewoo keyin remote pls
code for panatone plz
Code for fukuda tv??
ser code KTC??
