Grundfos UP15-29SF 1/25 HP Stainless Steel Circulator Pump  Logo
Gin Taras Posted on Apr 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my water circulator pump making a loud grinding sound ? Should I replace it, or repair it?
Gene Haynes
Level 3:
  • Grundfos Master 5,391 Answers
  • Posted on Aug 27, 2014
Gene Haynes
Grundfos Master
Level 3:
Answers
5391
Questions
0
Helped
2605825
Points
14124
Replace probably.
Clean impeller with white vinegar
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 • Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 06, 2013 • Dishwashers
1helpful
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 • Dishwashers
1helpful
2answers
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
I had this same problem that cropped up about 6 months after I purchased the ice maker. When it pumped water into the ice tray, the water pump would make a loud grinding noise. I inspected the pump and found that the impeller was in contact with the bottom of the pump housing. I partially disassembled the pump and inserted a small washer I fabricated out of electrical tape to enlarge the gap between the impeller and the bottom of the pump housing. I also took care not to over-tighten the screws when reassembling the pump. The grinding noise went away completely, and it's back to normal operation now. Even if you have no idea what you're doing, like me, it's a 15 minute fix with practically zero materials cost.
I have no idea what caused the problem originally, unless there was a washer that disintegrated over several months' worth of use.
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
1helpful
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
Sta Right model P2RASF-182L (RPM 3450) sounds like the bearings are gone...turns on, but is very loud and gets very hot.  The water is not circulating either.
If the noise you are hearing is like a grinding, then the bearings are gone. Sta-Rite does not make the motors for their pumps, either AO Smith, or Centurian, makes them, so they recommend that you replace the motor with a new one. You can try a small motor repair shop in your area.
If it is an AO Smith motor, you may be able to find more information at the following website:
http://www.aosmithmotors.com/html/products/productLiterature.html
Top Grundfos Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
