My Sharp Ar 5316 is showing F2 or 2F Error what...
It shows F and 2 and cannot copy
You need a service manual to solve this problem.
http://www.tradebit.com/filedetail.php/185184978-sharp-ar-5316ar-5320-service-manual
Problem is w/fuser (where it get's hot) lamp or thermofuse is blown, replace.
Repels that cram and resat your machine working ok,
Check fixing unit fuse or power supply board
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
SOURCE: SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If
these steps doesn't work you must call an authorized serviceman to
check your machine, maybe something is busted on the fusing unit like
thermostat or fusing lamp.
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
My Copier AR 5316
After replacing the Tonner it shows F2 and no other function working - Not copying.
Thanks
2f error display when ask to print
