Have ask how to reset governor on 19 hp kohler courage engine and i get everything but the answer to that
SOURCE: i have a 19 hp kohler courage on my toro zero turn
This sounds like the carb is plugged. Sometimes fuel thickens and makes globs...
If you verified the fuel flow to the inlet of the carb, then you need to take the carb off and open it up....
So, what needs to happen is you blow out all of the passageways with carb cleaner.
Any adjustable jets: make note of the position it is in, and FINGER TIGHT turn it clockwise until it closes (typically 1 to 1 1/2 turns) SOOOOO, you can set this jet back to the same positon....when finished blowing everything out, bottom the jet and back out the number of turns out, noted for that jet.
Open the float chamber, and clean as necessary, Inspect the float adjustment: invert the carb, and observe the angle of the float, relative to the carb body.... Usually almost parallel, but not necessarily.
Inspect the inlet valve, and clean those areas...
I usually use all new gaskets and valves, but if you are not a carb person, cleaning is effective and I think old gaskets may be okay, if not torn or damaged.
SOURCE: I have a Kohler Courage 19 on a Troy built lawn
sounds like you are on the right track, I would replace the needle and seat and also check the roll over solenoid that is on bottum of float bowl, some times they go bad and do that. and they have also had issues with needle and seat not sealing,. some people have put shut off valves on their line and turn it off when not using hope this helps you, don't forget the thumbs up!
Got a 18 hp koehler courage the governor arm is really hard to push what's up with it how do you adjust the thing
I've looked it's everything but whst I nereed
Does this one adjudt by sliding that linlage plate it's really stiff
