In this article, you will meet a very good recovery program that will handle all the stress for you. It won't require a technician after all. You can do the job easier and faster.
For better step by step procedures follow these guides:
Step1. Download FoneDog - Android Data Recovery, Install and Launch
Step2. Connect Samsung Galaxy S Note to the computer
Step3. Select Files for Data Extraction
Step4. Select Device Fault Type
Step5. Download Mode
Step6. Retrieve deleted messages by preview and selection
Hope it can help you sooner. Good luck.
SOURCE: Text message auto delete
http://dl.owneriq.net/f/f6e30b8d-ffc9-3af4-41b7-ac7bcf731c01.pdf
this is the manuel for your phone around page 37-47 has the function i can tell you my phone its under i click message settings auto erase but hope that guide helps
SOURCE: text messaging
I took a wack at it and it took me an hour to figure it out. Okay where is the way go to the messaging menu choose send message then go to Voice SMS okay then choose Recent List there you should see the recent contact you have texted to select the ones you want to delete and press options there you can delete the selected or delete all.
SOURCE: password protect text messages on lg rumor for sprint?
go to menu then settings then security then choose lock and restrict this will allow you lock different items on the device you choose
SOURCE: how to recover deleted text messages from the lg
If you go on to the menu and use the code 5,2 then press 0,1,1 very very quickly (if you dont do it quick enough then it will delete some of your messages) Then you go onto a screen of your deleted messages and you can chose to recover whatever one you want. HOPE IT WORKS :)
