Question about Creative Labs Gigaworks S750 Computer Speakers
How to connect my speakers to my sound card - Creative Labs Gigaworks S750 Computer Speakers
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 174 Answers
Install your advice you might conect it to an mixer from ther to your advice and from there to your speakers
Posted on Apr 17, 2012
6ya staff
SOURCE:
I have plugged in the USB from my Zalman 5.1 External Sound drive and I still do not have sound. Should it be connected to my computer speakers? If so where? I have two current plugs on my speaker; the...
Yes, the speakers must be connected to the device. Your speakers use an older color code for connections. The black plug from your speakers goes in the green socket on the device. There may be a black socket on the device, but due to the color changes, black now indicates a surround speaker connection, not the main speaker connection. I would guess, not seeing your speakers, that the tan plug is either for a microphone, or more likely, is how you connect the left speaker to the right one.
Mar 14, 2011 | Zalman Tech Zalman: Zalman External 5.1Ch...
MY OLD INSIGNIA SPEAKERS (WITHA SUB-WOOFER) WENT UP SO I GOT A SIMPLE 2 SPEAKER INSIGNIA 2.0 POWERED SPEAKERS. NOW I CANT GET ANY SOUND. ANY THOUGHTS?
1. Try looking in the taskbar of the Windows screen and selecting the volume control ( a speaker icon) check the mixer see if the volume is not muted or in the "0" position
2.Check the "input port on the sound card where you connected the new speaker assembly.
3. Check the volume control knob on the speaker assembly to see if it is not in the off or lowest volume position.
4. Check the new speaker by connecting them to another computer that has the sound already on and working this will let you know that the speaker assembly is good.
6. check the sound card drivers to the internal sound card that is on the mother board if this is where your sound card is located. Use the "manager" to see if it is working properly. If not then do a "reinstall of the sound card drivers or use the "update feature in the hardware window for the sound card to install the latest version of sound card drivers.
I hope this helps. Have a great day!
Sep 25, 2010 | Insignia 2.0 Speaker System (2-Piece)
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
Only 2 speakers work even though its all plugged in correctly. Ive hooked it up to an i pod
Hi , Just to clarify is your Sound Card that you are connecting it too , a 5.1 Channel Sound Card?? if not then that is the problem as it is a 5.1 Surround Sound System..Reason for it only coming out of 2 speakers when you connect it too an ipod , is the Green Cable Doesnt Comply with all the Speakers , you need a 5.1 CHannel Sound Card to connect all the Cables into.A 5.1 Channel Sound Card looks like this http://www.dclstore.co.uk/images/products/genius-soundmaker-value-5.1-channel-sound-card-16-bit-pci-31720009100-l.JPG
I hope this helped bud ,
Have a Happy new Year :)
Dec 26, 2009 | Logitech X-530 Computer Speakers
What is the sound card and where is it
The sound card is more often than not integrated into your motherboard, check your device manager and you will probably have a realtek sound card. If so it is integrated, the only ones that arent are the Turtle Beach and Creative Labs Soundblaster models which are PCI expansion cards plugged into the motherboard. Ive never heard of manufactured computers using a soundcard that isnt integrated unless you paid for that upgrade.
Jul 15, 2009 | HP Compaq Computer Speakers
Desktop sound card
i believe you have something connected wrg since your pc only requires one jack from sound card. to you subwoofer then its seperated to he others. read the book on *********** board to see if you can change your options on the sound configuration.
Nov 28, 2008 | Logitech X-530 Computer Speakers
Gateway Computer 710X Speakers are crackling/popping
It sounds as if the card itself may be physically bad. or you may have a microphone connected/something in your mic jack and you are picking up noise.
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
No sound. Sound card or speaker failure??
These speakers only accept digital input in form of 3.5mm mini-din digital out from your source.
Nov 09, 2017 | Boston Acoustics BA735 Computer Speakers
Hello
Hi uptown109
happy Holidays
well, depending on what brand of sound card, (onboard sound) or external sound card, you have to prove if you get sound (green) connector with a headphones, then connect the green cord from speakers to the green connector on sound card, go to control panel then and test and up in the mixer all volumes, see if not mute .
good luck
Dec 22, 2007 | Sakar Adrenaline Computer Speakers
Creative Labs Gigaworks S750 Computer Speakers Logo
59 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
