I need to secure/put a code on my router to avoid others to connect upon it
READ General Router Setup
SOURCE: wireless secured network key code
Hi BabyDoll - to find your key, log in to your router. Enter 192.168.0.1 into your browser. If the defaults haven't been changed, the user is " admin" all small case without the quotes. There is no password. Just enter the user and leave the password blank. To get the key, click on the wireless button on the left. Then look down the page and you'll see the passcode fields. This is what you're looking for. Also take notice of what's above it such as WPA, WEP, etc. Write this info down. You can also go into your pcs that you use wireless on and put that key in and the kind of security (WPA, etc) so that it will not ask for it every time.
If this solves your problem PLEASE rate this as fixed. If not, DON'T RATE YET. Let me know what happened and I'll be happy to assist you further. If you need to know how to enter the info so that you won't have to enter it all the time let me know. I'll help you with that. Let me know what happens. Thanks.
Jeff
SOURCE: securing a wireless connection
Plug directly into the wireless access point using a network cable and then navigate to the default IP address for configuration. Don't try to access it wirelessly.
SOURCE: my laptop can't find my wireless router
FIRST TRY: delite all previous wireless settings on your operating system.
try reseting settings, than configure with ethernal la, and delite all previous settings on your operating system.
SOURCE: unsecured connection
there are usually two ways to do this. one, your router should have came with a disk. if you run that disk it should walk you through step by step. if no disk, try typing 192.168.1.1 into the address bar. this should take you into the router diagnostics. in this, you should see some tabs about setting up the wireless settings. if neither one of these work, the best bet is probably calling dlink tech support for help.
SOURCE: how to make wireless network using DI 514 router
There is a great article at Working with Windows Wireless Networks
If you need more help post back!
Thumbs and testimonial are welcome!
Wireless Router settings:
It is usually easiest to run the install wizard, which you
can get from the manufacturers' website, usually for free, but be sure to be
ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or
192.168.0.1, or other address for your unit, into the ADDRESS bar (not search
box) of your Internet Browser. Every unit has unique access login and
passwords, some are admin with no password, some are admin and admin...seek
access information from the website of the manufacturer of your unit. Look
under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to
SAVE EVERY page before you leave it, or the changes will be lost. A geek knows
this (apparently). The router gives no protest...just dumps your changes. SAVE
OFTEN.)
1.
Login password (RECORD THIS!!). Consider taping
to bottom of the router. Physical access is typically NOT the security issue.
2.
Set a recognizable system ID (descriptive name
is easier to find when you need to connect wirelessly).
3.
Invoke wireless security of at least WEP.
a.
Assign your own access code, 10 digit home or
cell #. Consider taping this information to bottom of the router. (Physical
access is usually not the security issue.)
4.
Check that your router is set to broadcast its'
presence.
5.
Change the channel of the wireless to 11, and
avoid conflict with landline cordless phones. (Big issue, even the neighbors
can interrupt).
There are more secure settings available, all the way down
to only allowing certain MAC addresses to have access. A MAC address is a digit
unique to each and every network card. Like a fingerprint. Most users do not
set mac address limits.
Things to set:
OFTEN.)
1.
2.
3.
a.
4.
presence.
5.
can interrupt).
