Only lower part display in good picture, please advise
SOURCE: I have tv sony KV- XJ29M50 when switches on comes on for 10 - 30
shutdown trouble, some leak capacitor need to be replaced
SOURCE: My TV Sony KV-XJ29M50,
check vertical section.replace vertical ic.also check pin cushion section.
Testimonial: "Quite good, preferably more detail"
SOURCE: Where is the vertical part of the Sony KV-XJ29M50,
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 900 posts to different brand TVs now.
