Cars & Trucks Logo
Anonymous Posted on Sep 22, 2017
My 1993 chrysler lebaron le 3.0 engine v6 keeps running hot, I have replaced the thermostate, oil pressure sensor and oil change, after about three miles it says to check gauges, not sure of what els
My check gauges light keeps coming on after about three miles of travel, engine indicator trys to go to hot, I have replaced the thermostat, oil pressure sensor and did a =n oil change, yet I keep get check gauges, I have noticed in the mornings the radiator is empty yet I cant find a leak, thinking it is the water pump, but not sure how to tell. Please Help!!
obsteiner
Level 3:
  • Cars & Trucks Master 901 Answers
  • Posted on Sep 22, 2017
obsteiner
Level 3:
Answers
901
Questions
Helped
303291
Points
7223
You most likely have a blown head gasket and the coolant is being burned in the engine. Otherwise you would see evidence of a leak where the car is parked.
Robert Kulkofsky
Level 2:
Sergeant:
  • Cars & Trucks Expert 200 Answers
Robert Kulkofsky
Level 2:
Sergeant:
Answers
200
Questions
5
Helped
47350
Points
595
If your pump is leaking it will leave a puddle under the car.
3 Related Answers
Anonymous
  • 11 Answers
  • Posted on Jun 06, 2009
SOURCE: 2000 GS300 LEXUSVSC OFF AND CHECK ENGINE LIGHTS KEEP COMING ON
disconnect negeative (-) battery cable for 20 seconds....reconnect and start car. Check engine light should now be off. I
Anonymous
  • 2050 Answers
  • Posted on Sep 08, 2009
SOURCE: 2002 monte carlo overheating
Better make sure the fan works. There is a switch on the radiator that turns the fan on when it gets to a certain temperature. It could be the fan or the switch. Your thermostat is not your cap, it's in a different location. (Usually at the engine end of the upper radiator hose) Get the leak check! A good garage can pressure test the system to see what leaks you might have.
Anonymous
  • Posted on May 12, 2010
SOURCE: my 2000dhs is running hot. I replace water pump
Yes, this is very common problem of the northstar platform. Head bolts aluminum thread inside the engine block stretching. Although Cadillac improved it in 2000 year model, it persisted on a lot of cars. You will not see any water in oil, at least for the first 5-6 thousand miles, but it will get worse and worse every time, so aventually you will. Engine will "drink" your coolant and no kind of coolant additives will fix that. Especially big coolant loss will be if you floor your gas a lot. On the freeway however you can go for an about 100 miles before engine will consume most of the coolant and overheats. You need to fix the block, cadillac calls the proces "time sert" - they drill bigger holes in the block, thread it and put inside inserts with outer and inner threads, were your original head bolts will go. Dealer going to charge you $5500 for that, and most mecanics will charge around $3200. That is why so many people selling their caddys cheap on ebay saying that there is a coolant leak somewere. I bought two caddys like that. Now I can fix that kind of problem easy. I bought all of those expensive tools for time serting. And by the way, something I learn the hard way, even if you are mecanic but never ever rebuilded northstar before expect lots of problems and difficulties. Very complicated hi tech engine with balanser shauft. Parts are expensive too, upper set of guskets will cost you about $320 and if you buy all the lower seals too than $500. Piston rings $220 and good luck finding it in autozone. I guess it is time for you to find out how are those used car dealer shues fit you :-)
I have a1993 chrysler lebaron ,3.0 v6 where is oil sending unit located
no Not all ways true I changed the Oil sending unit on My 1993 Chrysler lebaron convertible 3.0 Now it is still Leaking and it is not the oil filter the leak is above the oil filter. some where it is not from the engine block area !!! I replace valve cover Gaskets . and Oil sending unit. thank u . still coming from above the Filter and it is not th e filer.......
1993 chrysler lebaron water pump diagram
If you need to add water a lot the engine is either leaking it overboard or is burning it internally. Take off the radiator cap and start the engine. Watch for bubbles in the water. If you see any, the head gasket is allowing compression gas into the radiator. When the thermostat opens, watch for how fast the water is circulating. Rapid tells you the water pump is ok. and the radiator tubes are clear of obstructions. Pull the oil dipstick. If water is in the oil it turns grey. This is the worst condition and may not be readily be repaired unless it is found that a blown head gasket is letting coolant into the oil.
1helpful
2answers
Type of oil 1987 LeBaron
On 1987 Chrysler Lebaron 2.2L FI Turbo 4cyl...
Engine Oil Type/Weight/Capacity (use in temperatures ranging from 19 To 81 degrees)
Note :
Pennzoil Premium Motor Oil 5W-30
Castrol GTX High Mileage 5W-30
4.5 Quarts without Filter change.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
12helpful
2answers
Serpentine belt diagram 1993 chrysler lebaron v6
To remove the serpentine belt from the 3.3L and 3.8L engines, rotate the tensioner assembly clockwise
2answers
Car tries to stall, going over 50 mph.
you may have a fuel flooding, try to replace your sparkplugs and hi tension wires. if the problem still exists try to replace the fuel filter and fuel pump. try draining your fuel tank too and get rid of the rust and dirt. hope this helps
1helpful
Chrysler le baron 1991 3.0 V6
If all you did was remove the pan and service it then 3 and 3/4 liters will fill it. If it was rebuilt and has no fluid at all then it will take 8 and 1/2 liters
1helpful
Speedometer sensor
follow the firewall down.halfway down on trans. you will find a three wire connector. that is your speedometer sensor
2helpful
Engine turns but won't start
Have you checked it for spark?
2answers
1993 Chrysler LeBaron oil pressure switch
j'aimerai entrer en contacte avec pour l'achat de votre vehicule
1helpful
1992 Chrysler LeBaron 3.0 L. V6 Engine runs beautifully but after 16-20 miles highway driving engine stalls as if flooded, or as if fuel is cut-off. After sitting for a few minutes, will start and run...
the owner probably rerouted the fuel line because like my 92 chrysler lebaron v6 3.0 the fuel lines keep seeming to come off and the clamps always break. I have replaced the clamps 5 times in a month and replaced filters 2 times in 2 months. The only thing i could think of is that your fuel is being cut off possibly because there is no filter to clean all the junk out. Try putting a fuel filter on and see if that will work
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
