Question about Panasonic Toughbook 52 Notebook - CF-52CCABCBM
Panasonic CF-52 Unusable USB Ports
The two USB ports on the back of my CF52 laptop are not usable
    Top Expert:
  • 5,051 Answers
Not usable? Are they broken?
Go into the bios and make sure USB is enabled. Restart your computer and look at the screen to see which key to hit to get into the BIOS or System Setup. Look for USB to make sure it is enabled.
If you have a pcmcia slot on your laptop, you can always buy a device that sticks into it that will have usb ports on it for less than $30 - $40. Otherwise you might need a repairman to take the laptop apart and solder new usb ports to the motherboard.
Posted on Apr 14, 2012
6ya staff
SOURCE:
Anonymous
  • 253 Answers
SOURCE: My Panasonic CF-74 doesn't seem to be detecting
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Posted on Jun 24, 2009
1234s282
Alex Smallwood
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
GuruGrundy
GuruGrundy
  • 71 Answers
SOURCE: instructions to replace the LCD screen on a Panasonic CF-52 Toug
Trying this link to see if you can get this information.
Its Panasonic's website, toughbook section
Also try this link.
Posted on Mar 19, 2009
leecom72
Lee Hodgson
  • 4806 Answers
SOURCE: The tab on the ethernet port has broke off so the
The NIC (ethernet port) is part of the laptop motherboard. To fix something like that you will have to be good at micro soldering.
I find it strange that there is a tab on the port itself, the locking tab's are usually on the RJ-45's (ethernet) cables themselves like in this picture>>>>
Regards.
Posted on Nov 13, 2009
Anonymous
  • 44 Answers
SOURCE: I have a panasonic CF-27EB and USB wont work.
Your port is probably damaged. Are you saying all USB devices are not working through the ports or a particular device is not working? Give me more detail please.
Posted on Feb 07, 2010
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Panasonic CF-VDRRT3
Check your connections and cables. From the look of the thing it is designed to work from the USB port on a desktop computer, a laptop gives less power through the USB ports, this is why most USB powered devices for laptops have 2 USB plugs for connection.
Oct 02, 2013 | Computers & Internet
CF-52 V Drivers
We couldn't really identify which drivers are missing. Here's what you can do. Boot to safe mode and check the device manager. Uninstall the drivers with problems and restart your computer. After that, install the drivers by going to the website of the manufacturer and download the drivers from there.
Use RadarSync if you want to update the drivers. This software is an automatic PC Updater (Drives).
David
Apr 03, 2013 | Panasonic Toughbook CF52 Notebook
Inermitent connectivity with cf-52
I would contact your internet provider for help to resolve this. This problem can most often be with their modems :)
Aug 01, 2012 | Panasonic Toughbook CF52 Notebook
Panasonic CF 52 Toughbook Windows XP install
If you choose to install Windows XP on the Panasonic CF52,
then please either order the original recovers DVD directly
from Panasonic, or if you wish to re-install from scratch yourself,
please use Windows XP SP3 (service pack 3) and NOT SP2.
You will find the drivers here:
Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
You can even re-install with this XP SP3 CD:
xpsp3-am4myvti2hob3hzqvrjwo1hl-4-0_0.jpg Just make sure to use your Windows XP COA license located
on the back of the Panasonic Toughbook which looks like this below
Good Luck to you and Regards from:
Richard, Montreal Based Panasonic Canada Toughbook
Authorized Dealer since 1989.
May 20, 2012 | Panasonic Toughbook CF52 Notebook
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Jan 03, 2010 | Panasonic Toughbook CF-51 Notebook
Nov 07, 2009 | Panasonic Toughbook CF-27 Notebook
Panasonic Toughbook 52 Notebook - CF-52CCABCBM Logo
2,606 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
