Hp support assistant 'how to fix'
Hp support assistant freezes when opened and displays 'an error occured'
    Top Expert:
  • 5,051 Answers
Remove it. Click Start/Control Panel and look for Programs and Features, or Programs (depends on your operating system). Uninstall the HP Support Assistant. It's not needed, just a bloated program on your system.
Posted on Apr 14, 2012
Anonymous
SOURCE:
HELP ! My HP C309a photosmart 3in 1 printer
Hello and Welcome!
The error
Oxc19a0040 is mostly occurred in HP printers
To solve the error code
Oxc19a0040,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Thank you for using FixYa!
Jun 08, 2012 | HP Photosmart Premium C309A All-In-One...
My computer just freezes up and the only thing I can do is restart it. Its been doing this since I bought it 3 years ago. HP can't fix it so I'm stuck with it. Its got the i7 chip with raid 1
Its a good pc and it must perform faster. If its slow then follow these guidelines::
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it. It's all junk and is a good place for "nasties" to hide.
If you want to speed up pc then use PCFresher.
Apr 26, 2012 | HP Computers & Internet
Hp pavilion a4311f, hp support assistant still frozen and 'a error occured'
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Apr 17, 2012 | HP Computers & Internet
I have an HP c5180 and i am getting an ink system failure reading Error oxc19a0021
Hello and Welcome!
The error
oxc19a0021 is mostly occurred in HP printers
oxc19a0021,Follow the given steps
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Aug 06, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
0xc18a0206, Follow the given steps
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
My dvd/cd rom is not working and is not displaying on my computer folder/dialogue box of hp pavilion dv6000 laptop it is not displayed wen i click on my computer to check it. Others; local disk, recovery...
click on the start button>in the start
search box type in regedit>now you will
see the regedit option listed there>click
on it and click on continue>now you will
have the registory editor window
open>here on the left hand side double
click on HKEY_LOCAL_MACHINE>under
that double click on SYSTEM>under that
double click on Current Control Set>now
double click on Control>now double
click on Class>now look for 4D36E965-
E325-11CE-BFC108002BE10318.click once
on this option.>now on the right hand
side look for "upperfilters" &
"lowerfilters".you may have both of
them or any one of them.just right click
and delete any such file.after this close
all the windows and restart the
system.if everything goes fine your dvd
drive should work fine.
Jan 20, 2010 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
108 people viewed this question
Ekse
Marvin
Marvin
