Kenmore 15864/15862 Top Load Washer Logo
Posted on Nov 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is draining fine, but only can get it to spin with a couple of pieces of clothing in it.
  • 1 more comment
  • capone01 Jan 06, 2010
    Our Kenmore 15864/15862 Top Load Washer, wont spin on the spin cycle. We replaced the 'Coupler", and still nothing. What should we try next?
  • Anonymous Mar 17, 2014
    wash and drain they both spin together at the same time
    the unit washes and drains and together spins all together at the same time
Anonymous
Level 2:
Scholar:
  • Expert 121 Answers
  • Posted on Nov 12, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
121
Questions
Helped
41431
Points
307
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
1helpful
2answers
KENMORE 90 SERIES TOP LOAD WASHER WONT SPIN LOUD NOISE, SOUNDS MOTOR RELATED. WILL DRAIN SLOWLY CLOTHES ARE STILL WET AT END OF CYCLE.
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
12helpful
2answers
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
1helpful
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
2helpful
2answers
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
62helpful
8answers
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Alexander
vince
