My 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.
Bottom (main oven) works fine but top oven and grill have ceased to function. The fan will run but the interior light does not work and neither the grill nor the oven generate heat.Also the control switches light up on the main oven but not on the problem one. It is as if all power has been lost to the top oven and grill but yet the fan continues to run when switched on.
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
