Sewing Machines Logo
Anonymous Posted on Apr 12, 2012
MC 6000 lcd screen not working
The LCD screen is not working on my Janome MC 6000
  • Anonymous Apr 14, 2012
    Everything else works on the machine except I can't view what is on the screen. I suspect it is a back lighting problem but I can't find info on the 6000 but perhaps the solution for the 8000 will work. I am going to try to replace the el sheet
  • melinda solomon
    melinda solomon Jan 29, 2015
    there is a button on the front of ur machine which ajust the light try that first , look in ur owner book to locate but it shows half light and dark
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Apr 12, 2012
Level 3:
Answers
7365
Questions
Helped
1741619
Points
19451
The computer motherboard may have gone out
1 Related Answer
bargainbox
Hassy
  • 1388 Answers
  • Posted on May 31, 2009
SOURCE: Janome Memory Craft 5700 LCD Screen
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
1helpful
2answers
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
1helpful
2answers
Screen dull on Janome mc 8000
There is an LCD Backlight Panel that illuminates the screen, and yes, they do fail.
Before you start, just check the screen contrast dial inside the top cover, front right, they can be easily knocked and this will also cause the screen to go light or dark.
Janome no longer supplies the LCD Backlight, however, we have an after market replacement at our store, and also provide fitting instructions and a good deal more besides.
If you care to contact me I can send a Diagnostic Routine and the Screen Reset instructions for you to check if there is anything else causing troubles.
Please remember to give details of your dilemma as we do receive a lot of requests.
Contact Link
Cheers
Martyn
2answers
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light.
https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
1helpful
3answers
Need touchscreen backlight for merory craft 8000 janome new home
Check this Link
4helpful
1helpful
2answers
Touch Screen for Janome MC 8000 required
We have the Janome MC8000 touch screen avaliable please contact us from our website www.sewingmachine.com.au
4helpful
3answers
The sewing advisor screen on a Janome 8000 is getting dim.
Check this Link
2helpful
3answers
Janome memory craft 8000
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
