Can anyone tell me how to change the ring tone on the above mentioned phone? All I have now is one long beep.
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
SOURCE: Ringer Help
Hi there, don't worry changing ring tone it's a very easy task. All you have to do is go to the main menu on your phone. From there you wanna go to settings, and you should see and option there to change the ringtone. In the other hand if your phone has sound files that can be used as a ring tone, then all you have to is go to the location of that file (it's usually located under "my stuff" "my music" etc) and select the file, from there you can select that file to assign as a ring tone. If you need further instructions you might want to put the make and model of your phone. Good luck!
SOURCE: Do I need a network?
If that model phone has a rj14 jack ( standard phone jack) and when you plug it into a known good wall jack and you can draw dial tone then it will work. If not it requires a KSU to interface with the lines and that's a lot more equipment than you need for 1 or 2 lines. Thank you. Jer
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
SOURCE: How do you turn the ringer back on a T7316E Nortel
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
Testimonial: "Thank you for your quick response, and help! Its most appreciated. So, for my next question How do I program the M7310 :)"
I would like to change the ring tone because the manual is missing. Can you help?
