Ok so it turns on but when it doesn't vibrate; when i try to move the intensity, it just beeps and E002 comes up. i don't know what that means!
SOURCE: I just replaced the pads
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
