Question about Air Tools & Compressors
Im 65 fires once then wont fire ive checked the gas and its in date
My im 65 fires once then packs in the fan engages but when you pull the trigger nothing happens ive had it repaired recently because the battery light showed red and green and the gun would not fire it worked fine for a while and now its misfiring again .can any body help
    Master:
  • 539 Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: nail gun won't fire
Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
Posted on Apr 09, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Posted on Jun 10, 2009
Anonymous
SOURCE: Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Posted on Dec 13, 2009
Testimonial: "Thanks for that, i will look into it! Thanks for your time.... Cheers, Steven. ;-)"
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: plaslode im250 second fix nail gun fires
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: hi .my im350 nail gun isnt working gas and battery
heatman101
Bostitch GFN1564K cordless nailer brand new wont fire.
take it back to the supplier for a replacement or warranty fix
however as it is electric there may be a safety switch that you have to engage to make it work as it would go off when ever and spray nails and staples every where.
Jun 27, 2015 | Stanley Bostitch Gfn1564k 15-guage...
Hitachi nr 90 gc2 nailer wont fire
Various reasons, secondary switch faulty. gas out of date, gas is colld, iar leak, faulty spark unit.
Suggest you get it checked out at a repair centre.
Jan 04, 2013 | Hitachi NR90GC2 Cordless Gas Clipped Head...
Pasload greenlight on fan on gun cleaned wont fire
Does it flash when you pull the trigger? Does the fan start? What model? Is the gas in date? Is the inlet valve the correct way up?
Oct 06, 2012 | Tools & Hardware - Others
IM250 not firing.
I know this post is old, but nothing worked for me until I tried the following.
little plastic triangle pin that fuel cell tip plugs into was somehow plugged in to far. pull that out, plug in gently, retry nailer.
Apr 12, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
Nov 01, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Pasload cordless finishing gun - still won't fire
barrel and fan cover 'o' rings may be leaking/ need replacing. item no 17 on the parts diagram.
Do you have a spark, you should just be able to hear the spark firing when the gun is applied to the work surface and the trigger pulled, it sounds like a click.if no spark heard it could be the switch on the fan head not working , a bad ignitor , or the spark is not sparking in the correct place, chaffed ignition wires.
is the gas you are using in date, there should be a date stamp on the gas bottle. if its out of date it can give problems.
Jul 19, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode nail gun will not fire. It makes all the noises that it normally make before firing a nail, but it doesn't do anything. I have hardly used this gun. The batteries are good and I have a new gas...
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
Apr 13, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode fixing gun has stopped firing
Do you have gas cylinder in,if so is gas expiration date on bottom of cannister,change gas to current fresh date. Also open nose of nailer and see if a fastner has logged ,remove and push plunger pin back into body,be sure to remove battery during these tests.
Mar 19, 2009 | Tools & Hardware - Others
Paslode cordless framer wont fire. new gas , charged battery,
K, this could be a couple problems. How far down did you take it to clean? Are you comfortable with removing the combustion chamber/housing from unit. There are 4 screws in the top cover and 2 down where the work contact is. Remove them leaving just the fan assembly and handle housing. Next locate the roller arm next to the fan assembly, put a fresh battery in tool and push the arm (KEEPING HANDS AWAY FROM FAN) the fan should come on, if not you probably have an electronic assembly that is bad, if it does come on it should stop in a few seconds. Next depress the trigger and again the fan should come on. Now to diagnose the firing unit. Depress the lever on the roller arm and hold in while pulling trigger, you should see a spark and also hear it where the plug is. If not then you either have a spark unit that is bad or a wiring problem. At this point I would take in for repair. The spark unit is around 90-100 dollars When you put back together did you also replace the orings or clean the ring grooves? Let me know if you have any questions
Jan 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Air Tools & Compressors Logo
198 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
