The power went out for a couple of hours. When the power came bake on the router wasn't doing its job any more. I pugged the ethernet line in my LAN card and the net was working. So the problem is definitely with the router. The thing is I think I tried everything, change settings, reset, hard reset but nothing seems to be working. In the router settings on the status tab it shows that it recognizes the connection to the internet but it doesn't seem to forward it to the LAN ports or wifi. Any help is appreciated!
SOURCE: Router not being recongized
Assumption Tried different ethernet cords,
WLan only blinks when accessing wirelessly, cables imply cable connection, or is this the cable connection between the router and modem.
Routers do NOT require software installed on the pc.
Connect the original pc that worked before the router was installed, by ethernet cable to lan1 port on the router.
type the address http://192.168.0.1 into your choice of browser to open the web interface on the router.
use the wizards of the router web interface to configure the wireless connections, record all settings and transfer to the pcs that should connect wirelessly. the helpscreens are very good and will explain what you are setting
do not install software to drive router to pc
SOURCE: D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
SOURCE: My router suddenly stopped working
Please try to access the router's configuration page by accessing 192.168.0.1 using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625
DIR-625 rev C:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625_revC
I tried to reconfigure the router but it is no working.
I meant that I plugged the router back in the outlet.
The really weird thing is that this happened to me a couple of months ago and the router didn't work for 2 day or so and then it just started to do its job again.
I didn't change the configuration and before the power outage the router worked just fine.
I cant figure out why is it doing this.
Any other ideas.
I also used the web interface to ping a website and it returned me a successful ping but still no internet connectivity if I try to use the browser of surfing.
