Bought this product like 3-4 days ago, it all went awesome until yesterday when i wanted to instal the driver that was on the cd i got in the box. After i tried that my mouse stopped working, the cursor won't move and when i check the mouse driver it says that windows can't verify the signature...
SOURCE: logitech mouse problem
sounds like you have reverse mouse enabled go into the control panel find the properties for you mouse, this should be a check box you can disable.
SOURCE: My kb-28g keyboard!
If you are running windows xp try running the system restore function on it.
SOURCE: razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
SOURCE: Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Your best course of action would be to use System Restore, based on your response above. Go back to the point where everything worked for you and don't attempt to update your driver again. If it works, don't fix it.
After that if there was something you wanted to accomplish, let us know and we can help you.
Regards,
Worldvet
SOURCE: Gearhead Mouse's cursor not moving.
Gearhead is known for making cheap products that have low quality. I would immediately take this product back and go with something else. Sorry, the best advice I can give..
