It "sees" it and it seems ok with the password or key i put in but then it won't connect. i have older laptop that willconnect . phone encription is WPA2 PSK, which might be the problem
SOURCE: hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
SOURCE: how to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Black screen when the hp dv7 stratup
Contact HP. There are known issues with the DV line of laptops. They die......seriously. Ask them if the problem qualifies your laptop for a "one time warranty enhancement". They might just fix it free as there are known problems with the DV series.
Hope this helps! Post a comment if not and I'll see if I can help.
Testimonial: "Well I will .... Thanks man ... "
SOURCE: Where is the print screen on my laptop HP
I'm having the same problem. There IS NO 'print screen button' to use with the function key. That's the whole problem!
SOURCE: I have a HP dv7 laptop it does not work with the
You most likely have a short in the AC adapter and I would replace it right away. I have had my dv 7 for a little over a year and had to replace mine 3 times so far.
