SOURCE: i want pc suit or want 2 know how 2 connect my motorola w230 2 pc
Check if your phone has any USB slots if it does you can use that just fine.
SOURCE: w230 cant connect to a pc
http://www.cellphone9.com/motorola-w230-file-transfer-problems-firmware-update/
follow the above line.... and probably you must have a memory card in the fone.... once you are done with downloading the driver
connect the fone and you would get the 'found new hardware baloon' select 'no not this time' and click next and browse to the driver which is downloaded, click next and finish the process...
once you remove and connect the fone you would get a prompt on the fone's display "connect phone as storage device" click yes to transfer data or click no or leave it alone for the fone to get charged...
hope this helps you..
use this alt link to download driver
http://direct.motorola.com/hellomoto/in/support/usb_drivers_pc_charging_drivers.asp
incase of any further clarifications vishal at games.com....
Cheers,
vishal...
