I am getting static even on the local radio stations.
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
SOURCE: I have a 2008 Toyota
Yes, it is possible. Every head unit has aux input, it might be an RCA or stereo plug. Just use an RCA to stereo jack cable or stereo to stereo jack cable.
After connecting the cable, you may now select aux input to the stereo and play your Ipod.
SOURCE: Reception on radio not clear after reattaching antenna
maybe its broken internally,its unusual
SOURCE: Poor FM radio reception 2010 Prius
Check the antenna connection where it connects to the stereo it may be loose or not in all the way.
SOURCE: how to install dash kit toyota avalon 2008
they are stick on kits not replacement parts,the kit has pieces cut out the same as your dash to fit over certain areas,or buy the factory pieces that are plastic made to look like wood and thats going to cost $100s for all the parts,get woodgrain kit much cheaper and looks very similar
SOURCE: i have a 2008 smart key for a toyota avalon. can
Yes, But if the key is used, the procedure is call reset the immobilizer ecu, not just program the key, this procedure is done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
