The Powermatic 1791264k Model 719T Tilt Table Mortising machine, works excellent and it is a very good equipment. I have no regret in purchasing this machine.
More details Make elegant choice with Powermatic 719T Mortiser Review
In most column drillsis a narrow rectangular recess above the chuck when it is rotated slightly downwards
therefore you should have one of these auxiliary tool
At least the wedge
Have not seen another system to remove a drill spindle
Check for an allen bolt. Open chuck all the way and look inside for an allen bolt some drill presse have gone to this method of attaching the chuck. Hope this helps.
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily.
Good luck,
Al K
paste this link into your browser address bar http://www.toolsandmachinery.com/powermatic-parts-5882/powermatic-drill-press-parts-6903/powermatic-2800-parts-6904/
thats the diagram and parts listing for the only available powermatic drill press ( 2800) , if its an older model you might find the parts on ebay , i have in the past used a recoil starter spring but it can be a pain to modify the spring to suit .
