I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
SOURCE: need a navigon 2100 user manual
http://www.navigonusa.com/_pdf/manual/Manual_2100_2120_English.pdf
this is your manual .
SOURCE: NAVIGON 2100 won't move as I go down the road.
garyboop1 Try just rubbing you finger accross the screen, it should give you some result. Rusty1
SOURCE: Navigon 7000T - SD card problem? Refuses to start up.
Sounds like the sd card is beginning to give you a problem, if you can find another sd card or just buy one, (they are less then 20 bucks now) copy the software from the original sd card and put it onto the new card. This should clear up the problem since it sounds like the cards lock is worn down to much for the sensor to feel it.
Testimonial: "Thanks for your input. I've followed your advice but when I insert the new card, it is not recognised - it says "insert memory card" do I need a 2mb?"
SOURCE: Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
SOURCE: Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use
Pin
Pin
Name
Description
+5V
5 Volts Direct Current
Data
floating/Not connected
Data
X
Ident
Conneted to Pin 4 (GND) as pure short, no resistor
Ground
Ground, shorted to pin "X"
Use of standard mini-b will place unit in
Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short
will allow use of Navigation software and concurrent charging. USB power
source must be 1000 ma or above.
Why wont it work?
