Hi I have tried 2 batteries from eBay sold as had a 2 hour test on a laptop and original .when I switch off charger ,goes dead instantly which indicates there is no power at all coming from battery. Not a meg,so I'm sure there must no an open circuit from battery.is ther a fuse or diode that could of failed?Hi
You can't post conmments that contain an email address.
Yes it still the same with a replacement battery in fact I,ve tried. Two tested replacement batteries.Yes it still the same with a replacement battery in fact I,ve tried. Two tested replacement batteries.
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
* Circuit breaker on main control box is tripped * Fuse blown (check fuse in main control box assembly). * Incorrect polarity at battery terminals * Dead batteries. * Charging cable is still connected to charging receptacle * One of the cable connections at the main control box is loose. * Control connection cable disconnected * Broken key switch * Throttle stuck fully open * Throttle control potentiometer broken. * Speed potentiometer broken * Battery voltage too low. * Faulty charging cable. * Charger not working. * Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary * If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Hi, the main fuse is on the starter solenoid I believe. If this is OK I would look to the battery. I have had my SV get me to work and after work tries to start then nothing shot battery every time. Try removing the battery please undo negative lead first. Connect battery to a dedicated bike charger (output 1 amp max) see if it will charge. A dead or faulty battery will normally show full charge very quickly do not be fooled by this the battery is lying. When you fit a battery please connect positive lead first. Please never use car or boost chargers and never jump start your bike from another vehicle.
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
Your phone could be suffering from:
A dead battery. Replace it.
A dead Charger not charging the battery, try a different charger to confirm. If dead replace.
A faulty power on switch. You need to confirm and replace it.
A dead phone (I hope not). If nothing works then the phone may be dead. Sometimes the connections snap with the slightest of jerks and the phone goes dead. You need to carry out the fault finding and rectify the fault.
If it still does not come on then replace the phone. But in this order.
How long have you had it and how long has it been doing this?
What sort of batteries does it take? Sounds like a battery connection fault, or a faulty battery to me.
Does it work from a mains connection (power supply)?
Do you mean that by leaving it sitting idle for 3 days after the fault appeared, it suddenly starts to work again? Without the charger connected? Sounds like a definite connection problem. Do you have a spare battery you can try in it? That woud be the most likely thing you can do for it. If that doesn't fix it, it will have a fault that a technician will have to repair. Sorry, can't help more than that.
I Have replaced battery still the same
Hi
