My emachines pc is running very slow and i cannot play games on it since i have restord it to factory setings can any one please help me sort it
Add more ram is the best way of speeding up a computer If your computer came with a motherboard disc the drivers could be on it Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers if you dont have a disk with the drivers you have to download them
you might have to many programs running at the same time putting to much strain on the CPU
try uninstalling a few unnecessary programs
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might further damage your computer
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over if you see
something running that you dont need running select end now then you might uninstall that particular program you might have virus slowing your computer
you might need to update your graphics card drivers
this should speed up your computer
hope this helps you
SOURCE: i want to reboot my pc to factory setting
All you need to do is insert the discs and follow the instructions. Though restoring this way adds a lot of un-needed additional software. I prefer to get a real copy of windows and do a fresh install. let me know if you need further assistance.
Thank you,
Lee
SOURCE: My need for speed carbon game is not working
my nfs carbon is not working first the screen becomes black and returns to desktop and asks for inconvience and says send error report and dont send
SOURCE: I wana restore my computer to its factory settings its emachine with xp on it
1) Go to start menu
(2) Click on all programs
(3) click on Emachine
(4) click on Emachine recovery management
(5) Click on restore on the bar across the top
(6) click on restore to system factory default
SOURCE: I have an emachine model# W3609. It's very slow
Back up all of your photos, documents, folders, files, favorites (bookmarks) and anything else you would like to keep and reinstall after the system recovery. Use a CD, DVD, flash drive, MP3 or external hard drive to store your data temporarily.
Click on the "System Recovery" icon (usually found within the start menu) and begin the process by following the on-screen prompts.
Click on "restore" and note the warnings about losing all of your data. Wait for the computer to complete the process of erasing the hard drive and creating a new partition.
Insert the emachines recovery disk in the CD tray when prompted. This will start the process. There are usually one or two disks involved and the computer will let you know which ones to insert when and will even eject the tray automatically in most cases. You may have to restart at least three times, do not be alarmed by this and keep the disk in until you are prompted otherwise.
Example of Windows Installation
Install Windows on the new partition and follow the prompts on your screen. Be sure to choose the largest partition, the one with the most kb available. There are usually two to choose from, as you have deleted the other ones in the steps prior.
Reinstall all of your backed up data and any software programs you are currently using, including the printer and Internet, if needed. Be sure all of your drivers and hardware is working properly, as they have been reinstalled as well during the recovery procedure.
OR
Click "Next" when the operating system restoration screen appears. Click "Repair Your Computer" and then select "Next."
Locate your eMachine's current operating system in the list of available operating systems, such as "Windows Vista." Click the appropriate choice and then choose "Next."
Select "Load Drivers" and wait for the drivers to finish installing. Select "System Restore" and then click "Next."
Scroll down through the list of available restore points. Select the first restore point if you want to completely revert the computer to factory settings. Select a later restore point if you just want to roll back any changes to your computer to an earlier date.
Click "Next" and then select "Finish." Click "Yes" and then choose "Restart" to restore the eMachines computer.
SOURCE: I have the EL1333G-01w emachine and would like to
yes you can upgrade your PC
folow the Site
http://www.walmart.com/ip/eMachines-320-GB-EL1333G-01w/13352324#ProductDetail
Can you give the model number and specs: Processor, RAM etc and a little more detail about why you restored the machine and how you did so.Thanks
i have checked everything and the computer says every thing working ok and the drivers are up tp date so i have loaded google crome and it works fine with google but it doesant work with out google crome
