Dometic RM2852 Refrigerator Logo
Anonymous Posted on Apr 10, 2012
RM2611 panel does not lite up or turn on - Dometic RM2852 Refrigerator
Where is reset button on rm2611
There is no reset button on that model. If your fridge wont turn on it is more than likely a fuse in the electronic board or that you do not have 12volt going to the refrigerator.
ArctiCold Refrigeration We keep it cold
CLEANING A CONDENSOR UNIT ON A DOMETIC RM2611
If its a small unit the condensor is built inside of the cabinet or its under the fridge or you can look at the back but most of , is this a rv type of fridge?
RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
Dometic Frige RM2611 stopped working when extreme cold weather set in
Yes they are designed to operate in a conditioned space. If it has a condenser fan motor you could put a cycle switch on it and that would extend it's operating range
3answers
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
2answers
Dometic rm2611 quit on the road today all lights
If the fridge is complete dead (no lights no fan, no compresor,etc.) looks like there's not power in the unit.Check if theres power in the oulet if you know how , if you don't put the fridge in an oulet that you know is power , if still doing nothing probably the cord is broken or burned and the power doesn't go throught it from the oulet to the fridge.
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
