WHERE IS THE POWER OUT LET FOR THE PHONE
SOURCE: Change Time on LCD for Toshiba DKT2020
Hello:
I had the same problem Yesterday.
The way uoi change it, is you have to find the phone with the lowest extension, either 0, 10, 100, 200 etc....
Once you find that phone, leave the handset on the base.
Press Intercome, you should hear the speakerhone activate.
Press #,652
You will see it say ENTER TIME
It's on a 24 hour clock. HHMMSS Format, so it it is 2:05P.M., you would time 1405XX (XX means seconds, obviously not at critical as the touror minute.
Then press REDIAL to submit the change.
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
SOURCE: Need to Change Time on My Phone
1. Press [DN] + #652 with the handset onhook.
2. Enter the time (HHMMSS) in the 24-hour clock format.
3. Press redial
4. Press speaker.
This can only be done from the programming phone (usually reception).
SOURCE: Password
Type in on telephone keypad:
5555#*
999#
999997#
Select Option 8
Select Option 4
Type in extension number you’d like to change followed by #
Select Option 5
Go to telephone you’ve just changed and type in 5555
Enter extension number followed by 997#
Select Option 3
Select Option 2
Select Option 3
Enter new security code followed by #
Confirm new security code followed by #
Hope this helps, Karen
SOURCE: Need Toshiba DKT-2010DS phone user guide
Dutifully, I have what you're asking for. With any luck it's what you need.
http://public.carl.airpost.net/Toshiba/Strata%20DK%20EKT%20User's%20Guide.pdf
Carl
