It started with the clock flashing and also letters PF were flashing. Then the electronic oven controller gives out sound signals and displays code F11. Even if I press cancel it doesn't stop it and I cannot reprogram the oven. thanks. Linda
F11 code is to indicate a shorted key on the touchpad, which explains your symptom...Replace the electronic oven control.
What is your model #? Help Me Find My Model Number RepairClinic com
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
F11 means a shorted button on the button board. This could actually be a shorted button, or it could be a bad connection to the embedded microprocessor. There is literally no way to tell without actually testing the unit. If the EOC module (electronic operator control) comes with a button pad, change them both out if you can't test them separately. Kenmore has other manufacturers make their equipment for them (frigidaire, whirlpool, electrolux, etc), so the generic equivalent board may be cheaper to buy somewhere else than sears. Your local appliance service center will know what parts fit what sears models. The model number you provided is useless to me.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
A part replacement is suggsted in the links above, but a technician might discover something else, rather than a particular part, as the internet search showed several possibilities.
